Previous Topic: /USE_NEXT_TIME /NOUSE_NEXT_TIME (D)
Next Topic: /VMS_COMMAND=vms_command
/USER_NAME=user_name
Specifies the OpenVMS username under which the new job will run. This value overrides the username of the person creating the job. For example, if the default username is MYJOB and you want the job to run under username YOURJOB, specify /USER_NAME=YOURJOB.
Note: You need the CMKRNL privilege to use a username other than your own. You cannot use the /GROUP or /TYPE qualifiers at the same time as the /USER_NAME qualifier. This is designed to avoid the potential for error.
