Previous Topic: /TYPE=type_name
Next Topic: /VMS_COMMAND=vms_command
/USER_NAME=user_name
Specifies a username under which to run the job for this job run only. The username overrides the original name in the database. For example: /USER_NAME=DOE.
When the job completes, the manager replaces this username with the original name.
Note: You must have CMKRNL privilege to run a job under a username other than your own username. You cannot use the /GROUP or /TYPE qualifiers at the same time as the /USER_NAME qualifier. This is designed to avoid the potential for error.
