Runs the job at the specified Job Management Manager delta time. The Job Management Manager delta time is the time interval from the starting time to a specified time in the future.
The delta time is added to the starting time. You must specify the days +dddd, even if you use 0.
For example:
Note: Job Management Manager delta time is not the same as OpenVMS delta time (dddd-hh:mm:ss.cc).
