CA Job Management for OpenVMS offers accessibility enhancements in the following areas:
Note: The following information applies to Windows-based and Macintosh-based applications. Java applications run on many host operating systems, some of which already have assistive technologies available to them. For these existing assistive technologies to provide access to programs written in JPL, they need a bridge between themselves in their native environments and the Java Accessibility support that is available from within the Java virtual machine (or Java VM). This bridge has one end in the Java VM and the other on the native platform, so it will be slightly different for each platform it bridges to. Sun is currently developing both the JPL and the Win32 sides of this bridge.
Display
To increase visibility on your computer display, you can adjust the following options:
Lets you choose font color, size, and other visual combinations.
Lets you change the pixel count to enlarge objects on the screen.
Lets you make the cursor easier to find or minimize its blinking.
Lets you make icons larger for visibility or smaller for increased screen space.
Lets you select color combinations that are easier to see.
Sound
Use sound as a visual alternative or to make computer sounds easier to hear or distinguish by adjusting the following options:
Lets you turn the computer sound up or down.
Lets you hear command options and text read aloud.
Lets you display visual warnings.
Gives you aural or visual cues when accessibility features are turned on or off.
Lets you associate computer sounds with specific system events.
Lets you display captions for speech and sounds.
Keyboard
You can make the following keyboard adjustments:
Lets you set how quickly a character repeats when a key is struck.
Lets you hear tones when pressing certain keys.
Lets those who type with one hand or finger choose alternative keyboard layouts.
Mouse
You can use the following options to make your mouse faster and easier to use:
Lets you choose how fast to click the mouse button to make a selection.
Lets you highlight or drag without holding down the mouse button.
Lets you reverse the functions controlled by the left and right mouse keys.
Lets you choose how fast the cursor blinks or if it blinks at all.
Let you do the following:
Keyboard Shortcuts
The following table lists the keyboard shortcuts that CA Job Management for OpenVMS supports:
Keyboard |
Description |
Ctrl+X |
Cut |
Ctrl+C |
Copy |
Ctrl+K |
Find Next |
Ctrl+F |
Find and Replace |
Ctrl+V |
Paste |
Ctrl+S |
Save |
Ctrl+Shift+S |
Save All |
Ctrl+D |
Delete Line |
Ctrl+Right |
Next Word |
Ctrl+Down |
Scroll Line Down |
End |
Line End |
