Using the Motif Interface › Overview › Changing the Resource Files
To change the resource files, follow these steps:
- Use the following command to copy the resource file to your DECwindows defaults directory:
$ COPY DECW$SYSTEM_DEFAULTS:SCHEDULER$MOTIF.DAT -
_$ DECW$USERDEFAULTS:*.*
By default, the logical DECW$USER_DEFAULTS points to SYS$LOGIN.
- Open and edit the SCHEDULER$MOTIF.DAT file to modify Job Management Manager resources. The file SCHEDULER$MOTIF.DAT has comments describing different parameters that you can change.
- Test the changes by restarting the DECwindows Motif interface. Repeat this step until the results match what you want.
