The manager’s flexibility allows you to choose from two user interfaces. The following table can help you select the interface to use:
Use this interface... |
If you need to... |
DCL |
Initiate and monitor operations using general and system management commands. Create dependencies. |
DECwindows Motif |
Create, modify, and monitor jobs as a general user. Create dependencies for complicated job streams as a general user. Obtain a graphical view of Job Management Manager jobs. |
