Previous Topic: How the Default Node Runs a Job Management Manager Job
Next Topic: Balancing Job Loads Among Nodes in an OpenVMS Cluster
Supporting Batch Mode Jobs in an OpenVMS Cluster
To support batch mode jobs in an OpenVMS Cluster, you should make all batch queues accessible to all nodes in the cluster. If this is not desirable, set up all queues to be accessible to the default node.
If you use the SHOW JOB command from a node that cannot access the batch queue for the job, the command will not be able to find the job.
