The following logical names supported by the manager provide flexibility around Batch job support:
If TRUE, the log files created by Job Management Manager jobs run in BATCH queues are kept. Otherwise, these log files are deleted when the job completes. This logical is defined initially in UJM$MANAGER$STARTUP.COM. The default value for this logical is TRUE.
If TRUE, the log files created by Job Management Manager jobs run in BATCH queues are printed to SYS%PRINT. Otherwise, the log files are not printed. This logical is defined initially in UJM$MANAGER$STARTUP.COM. The default value for this logical is FALSE.
You can use this logical to override batch name prefix of Job Management Manager. If you define this logical, the value of it is used as the prefix to the batch job name. If you do not define this logical, the default value SCHEDULER is used. This logical is not defined by UJM$MANAGER$STARTUP.COM.
