The following table shows the run time global symbols created by the manager each time it runs a job. You can reference these global symbols in your command procedures when a job needs information about itself.
For example, a job may want to read its comments (which can be specified in the RUN command), its job name within the command procedure, or its job number so that it can change its own operation.
Symbol |
Definition |
BATCH$RESTART |
The restart value set by the last SCHEDULE SET RESTART command within the job’s command procedure if the system failed while the job was running. |
NSCHED_COMMAND |
The job’s main OpenVMS command, created or modified by the job’s owner. For example: @SYS$DEVICE:[DOE.PROJ-C]WKLY-COPY.COM |
NSCHED_COMMENT |
The job’s text comment string, created or modified by the job’s owner. This is one way to pass information to a job at run time. For example: Check for weekly lists. |
NSCHED_GROUPNAME |
The job’s group, created or modified by the job’s owner. Examples: DAILY, WEEKLY, MONTHLY |
NSCHED_JOBNAME |
The job’s name, created or modified by the job’s owner. For example: WEEKLY-REPORT |
NSCHED_JOBNUM |
The job’s unique job number, automatically assigned by the manager when the job was created or copied into the job database. For example: JOB 747 |
NSCHED_OUTFILE |
The file specification for this job’s SYS$OUTPUT and SYS$ERROR output. For example: SYS$DEVICE:[DOE.PROJ-C]WKLY-REPORT.LOG |
NSCHED$RETRY_COUNT |
The number of times the job has been retried since it last failed. |
NSCHED$RETRY_MAX_ATTEMPTS |
The maximum number of retries allowed for the job. |
NSCHED_SEVERITY |
The severity element of the exit status of the job’s prefunction (if any) when checked from the job’s main procedure, or of the exit status of the job’s main procedure, when checked from the job’s postfunction. The value range and purpose are identical to those of the DCL symbol $SEVERITY. The value consists of the low order 3 bits of the job exit status. As per OpenVMS condition values conventions, even values signal a fatal error, an error, or a warning. Odd values represent either success or informational conditions. See also the symbol NSCHED_STATUS below. |
NSCHED_STATUS |
The exit status of the job’s primary OpenVMS command when last run by the manager. This status is used by the jobs that depend on that job and by the job’s postfunction (if any). Refer to Prefunctions and Postfunctions in Chapter 2, "How Job Management Manager Works," for a discussion of prefunctions and postfunctions. |
NSCHED_STEP |
Symbol defined for a job when it is run (similar to NSCHED_COMMAND or NSCHED_JOBNAME). It has one of the five following values, indicating the current step of job execution from the manager perspective: NSCHED_PRE_START NSCHED_PRE_RUN NSCHED_MAIN_START NSCHED_MAIN_RUN NSCHED_POST_RUN |
NSCHED_TYPENAME |
The job’s type, created or modified by the job’s owner. For example: PROGRAM, DOCUMENTATION, BACKUP, PROJECT-COSTS |
NSCHED_VERSION |
Symbol defined for a job when it is run (similar to NSCHED_COMMAND or NSCHED_JOBNAME). It is an 8-character string that indicates the version number of the manager. |
$VSSRESTART |
The job’s current restart flag, set by the manager. This flag’s setting is TRUE only if the job is set for RESTART. Otherwise, the setting is FALSE. Refer to the /RESTART qualifier for the SCHEDULE CREATE command for more details about job restarts. |
