Previous Topic: Setting Up Jobs
Next Topic: Stopped Jobs
Mail and Broadcast Messages
How do I turn off the manager’s broadcast messages?
When you create or modify a job, use the /PROMPT qualifier and answer no to the Notify prompt. (The default answer is yes, notify on completion.)
Example
SCHEDULE> CREATE/PROMPT
_VMS Command: @dua1:[example.notes]nightly_notes.com
_Job Name [None] : extract_notes
_Group [None] : notes_group
_Type [None] : nightly
_Stall Notify [None] :
_Stall Time Job [None] :
_Schedule Interval [None] : d 03:00
_Days [ALL]: (all,nosat,nosun)
_Special Day Restrictions [None] :
_Start Time [15-JAN-2012 03:00:00.00] :
_Output file [None] :dua1:[example.notes]nightly_log
_Mode (Detached, Batch, Remote [DETACHED] :)
_Cluster Node [Default] :
_Retain (Success, Error, None or All) [ALL]:
_Restart (Yes, No [Yes]:) N
_Retry (Yes, No [No]:)N
_Notify (Yes, No [No]:
_Send_Mail (All, Error, Success or None) [NONE]:)error
_Send MAIL on Special Day Action (Yes, No [No]:
_Use_next_time (Yes, No) [No]:
OPCOM (Yes, No) [No] :
_Mail_Address [EXAMPLE] :
_User_Name [EXAMPLE] :
_Run Priority [Default] :
_Pre Function [None] :
_Post Function [None] :
_Maximum Time Warning [None] :
_Maximum Time Job [None] :
_LBAL Group [None] :
_Synchronization [None] :
_Comment [None] : This job extracts nightly notes
%NSCHED-I-RQSTSUCCSS, Job 1 – Created
You could also use /NONOTIFY with SCHEDULE CREATE or SCHEDULE MODIFY, as follows:
SCHEDULE> CREATE "@user$s:[smith]foo.com" -
_SCHEDULE> /INTER="+0 00:30" -
_SCHEDULE> /GROUP=personal -
_SCHEDULE> /TYPE=daily -
_SCHEDULE> /NAME=myjob
_SCHEDULE> /NONOTIFY/NOPROMPT
%NSCHED-I-RQSTSUCCSS, Job          2 - Created
How do I send mail notification to a distribution list instead of a single user?
Use the following command:
SCHEDULE> MODIFY job_name
/MAIL_ADDRESS="@device:[directory]filename.DIS"
The default location for files referenced in the manager (such as output files and files referenced in the OpenVMS command) is the owner’s SYS$LOGIN. You must specify the exact device and directory if the file is not in SYS$LOGIN.
You must enclose the mail distribution list in quotation marks.
