Possible Causes |
Possible Solutions |
Incorrect interval |
Fix interval |
Output file disk full |
Check for insufficient disk space |
Output file disk not accessible |
Check for or disk not mounted or in mount verify timeout |
Node restriction |
Relax or modify node restriction |
Special Day Restrictions |
Relax or modify Special Day Restrictions |
Dependencies not satisfied ([ ]) |
1.Check parent jobs for successful completion 2.Check for new or changed remote cluster aliases in job records. See Repairing Job Records Containing Stale Cluster Aliases in this guide. |
Dependencies failed |
Check parent jobs for reasons for failure |
Remote dependency or network down |
Check why network connection is not available |
Dependency did not run |
Check why parent job did not run |
Dependencies entered, but interval not entered |
Check interval, or set interval to 0 |
One or more dependencies satisfied unexpectedly |
Check for manual or out-of-order runs of parent jobs |
On HOLD |
Release job |
No job slots available |
Wait, increase /MAX_JOBS |
Incorrect next run time |
Modify job’s next run time |
No privilege to run |
Check ownership, privileges, names, identifiers |
Job was not scheduled for expected time |
No action required |
Load Balance Group assigned to the job is empty |
Add one or more nodes to the Load Balance Group or remove the Load Balance Group from the job |
