Some Job Management Manager commands use qualifiers that require you to specify time intervals using OpenVMS delta time. Here is the format for OpenVMS delta time:
dddd-hh:mm:ss.cc
Note: At the DCL prompt, the /MAX_TIME and /STALL_TIME qualifiers require use of OpenVMS delta time; in all other interfaces, including the shell, these qualifiers use Job Management Manager delta time.
