In addition to the UIC privilege-based security scheme, you can control job access through Job Management Manager using rights identifiers. Each job may have the following identifiers:
If the requesting process also holds that identifier, then access is granted. This feature allows access control to individual jobs on a user-by-user basis, and eliminates the need for privileges for operations personnel. It also removes the need for privileged proxy accounts for remote control of privileged jobs.
These identifiers... |
Also permit these accesses... |
WRITE |
EXECUTE and READ |
EXECUTE |
READ |
The identifiers that are supported in the manager are "general identifiers," or identifiers that can be created with the OpenVMS AUTHORIZE utility and stored in the file RIGHTSLIST.DAT:
Identifier qualifiers do not appear in the DCL user interface as prompts to the CREATE, MODIFY, or COPY commands; they must be explicitly specified on the command line. In the DCL interface, the following qualifiers control the identifiers:
Identifier qualifiers appear in the DECwindows user interface.
The following privileges are required to set job identifiers:
Only one identifier value is supported for each of the identifier access qualifiers.
