To create a Job Management Manager job, use the SCHEDULE CREATE command. When you create the job, you can assign a job name and specify other information about the job such as:
The following is an example of how to create a job with the SCHEDULE CREATE command. When you use the /PROMPT qualifier with the command, the manager prompts you for all the information you can specify about that job.
SCHEDULE> CREATE/PROMPT _VMS Command: @SYS$DEVICE:[EXAMPLE.PROJECT-C]WEEKLY-COPY.COM _Job Name [None] : WEEKLY-RENAME _Group [None] : WEEKLY _Type [None] : PROJECT-COSTS _Stall Notify [None] : _Schedule Interval [None] : F W6 18:00:00 _Days [ALL]: (NONE,FRI) _Special Day Restrictions [NONE]: _Start Time [ 7-DEC-2011 18:00:00.04] : _Output file [None] : SYS$DEVICE:[EXAMPLE.PROJECT-C]WEEKLY- RENAME.REP _Mode (Detached, Batch, Remote [Detached] :) _Cluster Node [Default] : _Retain (Success, Error, None or All [ALL]:) ALL _Restart (Yes, No [Yes]:) YES _Retry (Yes, No [No]:) YES _Notify (Yes, No [Yes]:) NO _Send_Mail (All, Error, Success or None [NONE]:) ALL _Send MAIL on Special Day Action (Yes, No [No]:) _Use_next_time (Yes, No [No]:) YES _OPCOM (Yes, No [No] :) _Mail_Address [EXAMPLE] : EXAMPLE _User_Name [EXAMPLE] : EXAMPLE _Run Priority [Default] : _Pre Function [None] : DIR/PRINT[EXAMPLE.PROJECT-C]*.REP _Post Function [None] : DIR/PRINT[EXAMPLE.PROJECT-C.WEEKLY]*.REP _ _Maximum Time Warning [None] : _Maximum Time Job [None] : \-_LBAL Group [None] : _Synchronization [None] : _Comment [None] : Check for weekly rep's/copy to subdirectory and rename/check new rep files %NSCHED-I-RQSTSUCCSS, Job 10521 - Created
