A Job Management Manager job is represented in the database by a job record. You create most of the job database information when you create, copy, or modify job characteristics, such as:
The primary part of a job record is a Job Management Manager command, which is any valid system-level command you want to perform. To enter a command, you use the standard command format for the operating system that the command executes on. In the DCL interface, use quotes to enclose a case-sensitive command.
Any user can create a job record or copy a record to the Job Management Manager job database.
Note: The default location for files referenced in a Job Management Manager command is your SYS$LOGIN device and directory. You can specify a different device and directory as part of your file specification.
The following table documents the limit for text attributes in the job record:
Job Attribute |
Maximum Length |
Cluster node |
6 |
Comment |
80 |
Group |
40 |
Job name |
40 |
Load balance group |
14 |
Mail to |
50 |
Output (job log file) |
255 |
Queue (batch mode) |
31 |
Postfunction |
1024 |
Prefunction |
1024 |
Remote node |
72 |
Restart parameter |
40 |
Type |
40 |
Username |
32 |
VMS command |
1024 |
All time specifications |
23 |
