The wide area network feature allows you to:
When you set up remote synchronizations to jobs that run in a cluster that has an alias, always set the remote synchronization in terms of the cluster alias. This set up lets the dependency be satisfied regardless of what node the job runs on. If the job on the cluster is node restricted, set the dependency to that node.
The following commands and qualifiers are not supported over the network:
Commands |
Qualifiers |
COPY |
/MODE /QUEUE /EXID /RDID /WRID /SJOB /TJOB /OPCOM /CPULIMIT /REMOTE_NODE /SYNC=remotenode::job /LOAD_BALANCE_GROUP |
CREATE |
/MODE /QUEUE /EXID /RDID /WRID /SJOB /TJOB /OPCOM /CPULIMIT /REMOTE_NODE /SD_CLASS /SYNC=remotenode::job /LOAD_BALANCE_GROUP |
DELETE |
/SD_CLASS /IGNORE |
HELP |
MODIFY |
SCRIPT JOB |
SET JOB |
SET RESTART_VALUE |
SHOW DELETES |
SHOW DEPENDENCIES |
SHOW FISCAL_YEAR |
SHOW JOB |
/PROCESS /QUOTAS /ACCOUNTING /RIGHTS /PRIVILEGES /VERIFY_REMOTE |
SHOW SD_CLASS |
