Coding the Label Print Subroutine
You can use CA EPIC for z/VSE to create gummed dataset labels for output tapes automatically.
A CA EPIC for z/VSE program gathers information about a tape dataset when it is opened. You write a subroutine that formats the information and prints the label.
When an output tape dataset is opened, CA EPIC for z/VSE creates the following 58-byte record:
Field
Length
Dataset name
17 bytes
Volume serial number
6 bytes
Job name
8 bytes
Partition ID
2 bytes
Date
8 bytes (mm/dd/yy)
Time
6 bytes (hhmmss)
Tape device number (cuu)
3 bytes
Density
2 bytes (C0, C8, D0, and so on)
CPUID
4 bytes (binary)
Tape volume sequence
2 bytes (binary)
CA EPIC for z/VSE then passes the record and control to your subroutine. Your subroutine formats and prints the label, and then passes control back to CA EPIC for z/VSE.
You can print labels from CICS or in batch mode. Printing dataset labels in batch mode requires a dedicated printer and a dedicated partition. To print dataset labels online requires a dedicated printer and a dedicated terminal unless you start the transaction through the PLT. If you start the transaction through the PLT, you must dedicate a printer port to the transaction. That printer port can be freed by deleting the transaction from the PLT or by running the batch program ‘TSIDPEN’ as shown below:
// EXEC TSIDPEN
The RMNTPRT configuration option must be set to YES.
You can write your subroutine in either COBOL or Assembler. You can use the copybook record layout TSIDBPR.C or TSIDPRT.A. Sample Assembler and COBOL subroutines are provided to demonstrate the coding technique required to print tape labels in a batch partition. These programs can be found in the CA EPIC for z/VSE installation library under the names TSIDPR.C and TSIDPR.A (COBOL and Assembler respectively). Both Assembler and COBOL subroutines should open the printer file (DTF) only once to avoid depletion of Partition GETVIS. The COBOL subroutine program ID must be TSIDPR to avoid a conflict with the entry point name which must be defined as TSIDPR1.
