Deactivating and Reactivating CA EPIC for z/VSE by Partition
TSIDDEB deactivates and reactivates CA EPIC for z/VSE by partition. It can also be used if it is necessary to turn CA EPIC for z/VSE off to run a job. CA EPIC for z/VSE must be reactivated when the job is finished.
EPICOFF deactivates CA EPIC for z/VSE in a partition. xx specifies the partition ID. If you don't specify a partition ID, CA EPIC for z/VSE is deactivated in the partition in which TSIDDEB is run. For dynamic partitions, do not include the partition ID. Deactivation in dynamic partitions is effective only until end of job.
EPICON activates CA EPIC for z/VSE in a partition. xx specifies the partition ID. If you don't specify a partition name, CA EPIC for z/VSE is activated in the partition in which TSIDDEB is run. For dynamic partitions, do not include the partition ID.
