Turning CA EPIC for z/VSE On (TSIDON)
CA EPIC for z/VSE is activated and configured by using the TSIDON program.
Once CA EPIC for z/VSE is activated in a single partition, it becomes active in the rest of your partitions when the first dataset is opened. Once activated, CA EPIC for z/VSE remains active until VSE is IPLed or until CA EPIC for z/VSE is deactivated. You can turn CA EPIC for z/VSE off and back on in a partition by using TSIDDEB.
TSIDON is usually executed from the EPICON procedure. It can also be executed from the operator console or from JCL. When you execute TSIDON from a procedure, the procedure must be cataloged with DATA=YES.
