Defined Detection Modules
You can configure the following hardware inventory detection modules to collect the inventory for all or any of the agents in the domain.
The following module is automatically configured on all the agents regardless of whether asset management is installed:
The following modules are available only if you have the asset management agent installed. These modules can be configured only on Windows agents:
The following modules can be configured on all the agents:
The following modules can be configured only on UNIX/Linux agents:
Note: Depending on the operating system installed on the agent computer, the asset management agent launches the executable file associated with each module to collect the inventory information. If a platform-related executable file is not specified, nothing is executed.
