Maps fields from Files Properties or from Task Information, Resource Information, and Assignments in Microsoft Project to fields in CA Clarity PPM.
Microsoft Project |
CA Clarity PPM |
Notes |
None |
PRNote: PRCREATEDBY |
This field is set to the name of the current user when saving the project to CA Clarity PPM. |
None |
PRNote: PRCREATEDTIME |
This field is set to the current system time when saving the project to CA Clarity PPM. |
Comments field for projects Notes field for tasks, resources, and assignments |
PRNote: PRVALUE |
Concatenates multiple notes on the same object (i.e., project, task, resource, or assignment) into a single Notes field when opening the project in Microsoft Project. |
The Internal ID is the key used to identify the note when saved to CA Clarity PPM. Do not edit the note or any information. New notes are added after the Add new note(s).
The Intern[date/time note was entered by the user (internal ID)]
note #1
note #2
Add new note(s) under here:
A hard return starts a new note. Blank lines are removed.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
