Use the following fields to map task information:
Maps fields from Task Information in Microsoft Project to fields in CA Clarity PPM.
Microsoft Project |
CA Clarity PPM |
Notes |
General tab |
Name |
Tasks Properties: Name PRTask: PRNAME |
When saving the project to CA Clarity PPM, this field is set to the CA Clarity PPM internal ID if it is blank in Microsoft Project. This field cannot be blank. |
Text1 |
Tasks Properties: ID PRTask: PREXTERNALID |
Task ID’s in the same project must be unique in CA Clarity PPM (except blank). |
Start |
Task Properties: Start PRTask: PRSTART |
The same calendar information is reflected in the Set Working Time in Microsoft Project. |
Finish |
Task Properties: Finish PRTask: PRFINISH |
The same calendar information reflected in the Set Working Time options in the Change Working Time dialog. |
Duration |
Project Tasks: Duration (not displayed by default) PRTask: PRDURATION |
In Microsoft Project, the duration unit is set by the Duration Is Entered In field on the Schedule tab in the Tools Options dialog box. Elapsed durations are converted to their equivalent in worktime duration, but the model is changed. |
Priority |
Project Tasks: Priority (not displayed by default) PRTask: PRPRIORITY |
Priorities are translated between Microsoft Project’s range (0-1000) and CA Clarity PPM's range (36-0). Precision is lost. |
Flag1 |
Task Properties: Key Task PRTask: PRISKEY |
This is the default mapping, which can be changed. |
Text5 |
Task Properties: Charge Code PRTask: PRCHARGECODEID |
The charge code's ID (PREXTERNALID) is shown in Microsoft Project. To modify the charge code for a task, you must enter any existing CA Clarity PPM charge code ID. This is the default mapping, which you can change. |
% Complete |
Project Tasks: Tasks: % Complete PRTask: PRSTATUS and PRTask: PRPCTCOMPLETE |
The task status is set to Started when the percent complete is greater than 0%, or to Complete when it is 100%. Otherwise, this field is set to Not Started. Note: The physical % complete in Microsoft Project 2002 is not mapped. |
Advanced tab |
Mark Task as Milestone |
Task Properties: Milestone PRTask: PRISMILESTONE |
In Microsoft Project, any task can be flagged a milestone as a means to drive Gantt bar rules (e.g., drawing the diamond) and other features such as filtering. Microsoft Project automatically sets this flag when a task acquires a zero duration. |
Calendar |
You can use them in Microsoft Project, but the list of available calendars comes from CA Clarity PPM. |
Task Type |
Fixed Duration PRTask: PRISFIXED |
All types in Microsoft Project are supported. In Microsoft Project:
Effort Driven |
No Mapping |
Tasks flagged as Effort Driven in Microsoft Project take more processing. If there are many tasks, system memory requirements and performance may degrade noticeably. |
Constraints Constraints defined in Microsoft Project are stored in CA Clarity PPM, but you cannot edit them from CA Clarity PPM Schedule Connect. Microsoft Project automatically sets the Start No Earlier Than constraint when it is needed to hold a task start date. If there is a saved Start No Earlier Than constraint and Microsoft Project sets a later Start No Earlier Than constraint to hold a task start date, the saved Start No Earlier Than constraint is not set. |
Constraint Type |
No CA Clarity PPM user interface field available PRConstraint: PRTYPE |
When opening the project in Microsoft Project, CA Clarity PPM Schedule Connect only processes the first constraint it encounter if there are multiple constraints in CA Clarity PPM for a task. |
Constraint Date |
No CA Clarity PPM user interface field available PRConstraint:PRTIME |
Maps fields from task baseline information in Microsoft Project to fields in CA Clarity PPM.
Microsoft Project |
CA Clarity PPM |
Notes |
Baseline Start |
Task Properties: Baseline: Baseline Start (Not displayed by default) PRJ_BASELINE_ DETAILS: START_DATE |
Baseline Finish |
Task Properties: Baseline: Baseline Finish (Not displayed by default) PRJ_BASELINE_ DETAILS: FINISH_DATE |
Task Properties: Baseline: (Not displayed by default) PRJ_BASELINE_ DETAILS: PREXTENSION |
Baseline Cost |
Task Properties: Baseline: Baseline Usage (Not displayed by default) PRJ_BASELINE_ DETAILS: USAGESUM |
You must have Modify Baseline rights to save a baseline to CA Clarity PPM. |
Duration |
Task Properties: Baseline: Duration (Not displayed by default) PRJ_BASELINE_ DETAILS: DURATION |
No mapping |
Created_Date (not displayed by default) PRJ_BASELINE_ DETAILS: CREATED_DATE |
When saving the project to CA Clarity PPM, this field is set to the current system date if baseline information is present in Microsoft Project. It is not the actual date the baseline was modified in Microsoft Project. |
Maps fields from the File Properties in Microsoft Project to fields in CA Clarity PPM.
Microsoft Project |
CA Clarity PPM |
Notes |
Hyperlink base |
Task Properties: Guidelines PRJ_PROJECTS: PRGUIDELINES |
Text2 |
No CA Clarity PPM user interface field available PRTask: PRGUIDELINES |
This is only the portion of the guidelines URL that is directly associated with the task. This is the default mapping, which you can change |
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
