Project Information Field Mapping (Microsoft Project)
The following are the field maps for project information:
Schedule Field Mapping (Microsoft Project)
Maps fields from Project Information in Microsoft Project to fields in CA Clarity PPM.
Microsoft Project
CA Clarity PPM
Notes
Start Date
Project Properties: Main: Schedule: Start Date
PRJ_PROJECTS: PRSTART
Finish Date
Project Properties: Main: Schedule: Finish Date
PRJ_PROJECTS: PRFINISH
Schedule From
Project Properties: Schedule: Start Imposed (not displayed by default)
PRJ_PROJECTS: PRSTARTIMPOSED
Project Properties: Schedule: Finish Imposed (not displayed by default)
PRJ_PROJECTS: PRFINISHIMPOSED
If Start Imposed is set to “on” in CA Clarity PPM, the Schedule From field is set to the Project Start Date when opening the project in Microsoft Project. Otherwise, Schedule From is set to the Project Finish Date.
If the Schedule From field is set to the Project Start Date in Microsoft Project, the Start Imposed option is set to On and the Finish is imposed is set to Off when saving the project to CA Clarity PPM. Otherwise, Finish Imposed is set to On and the Start Imposed is set to Off.
Status Date
Project Properties: Schedule: As Of Date
PRJ_PROJECTS: PRASOF
Since Microsoft Project does not allow this field to be programmatically set to NA, the existing value in this field is retained if the AS of Date in CA Clarity PPM is blank.
Calendar
Calendar
PRCalendar: PRVALUE
When opening the project in Microsoft Project, this field is set to CA Clarity PPM’s configured system calendar.
This field is not saved back to CA Clarity PPM.
Priority
Project Properties: Schedule: Priority
PRJ_PROJECTS: PRPRIORITY
Priorities are translated between Microsoft Project’s range (0-1000) and CA Clarity PPM range (36-0).
Project Baseline Field Mapping (Microsoft Project)
Maps the fields in Microsoft Project to fields in CA Clarity PPM.
Microsoft Project
CA Clarity PPM
Notes
Baseline Start
Project Properties: Baseline: Baseline Start (Not displayed by default)
PRJ_BASELINE_
DETAILS:
START_DATE
Baseline Finish
Project Properties: Baseline: Baseline Finish (Not displayed by default)
PRJ_BASELINE_
DETAILS:
FINISH_DATE
Baseline Cost
Project Properties: Baseline: Baseline Cost (Not displayed by default)
PRJ_BASELINE_
DETAILS:
COSTSUM
Baseline Work
Project Properties: Baseline: Baseline Work (Not displayed by default)
PRJ_BASELINE_
DETAILS:
USAGESUM
No mapping
PRJ_BASELINE_
DETAILS: CREATED_DATE
When saving the project to CA Clarity PPM, this field is set to the current system date if baseline information is available from Microsoft Project. It is not the actual date the baseline was modified in Microsoft Project.
Manager Field Mapping (Microsoft Project)
Microsoft Project
CA Clarity PPM
Notes
Company
INV_PROJECTS:
PRDEPARTMENT
Manager
Project Properties: Main: General: Manager
When opening the project in Microsoft Project, this field is set to the user name in CA Clarity PPM identified as the project manager. This value is not saved back to CA Clarity PPM.
Title
Title
SRM_PPROJECTS:
NAME
Company Field Mapping (Microsoft Project)
Microsoft Project
CA Clarity PPM
Notes
Company
INV_PROJECTS:
PRDEPARTMENT
Other Project Attributes Field Mapping (Microsoft Project)
Microsoft Project
CA Clarity PPM
Notes
Text5
Project Properties: Main: Schedule: Charge Code
PRJ_PROJECTS: PRCHARGECODEID
The charge code's ID (PREXTERNALID) is shown in Microsoft Project. To modify the charge code for a project, you must enter a charge code ID that already exists in CA Clarity PPM to save the project back to CA Clarity PPM.
This is the default mapping, which you can change.
Calendar Field Mapping (Microsoft Project)
Maps fields from Change Working Time in Microsoft Project to the Administration Base Calendar fields in CA Clarity PPM.
The project calendar in Microsoft Project is always reset to the system calendar from CA Clarity PPM.
Microsoft Project
CA Clarity PPM
Notes
For
Calendar Name
PRCalendar: PRNAME
Not used for resource calendars.
Base Calendar
Base Calendar
PRCalendar: PRBASECALENDARID
In Microsoft Project, only resource calendars have base calendars.
Combines system calendars with their base calendars when this information is set in Microsoft Project.
Set Working Time for Selected Dates
PRCalendar: PRVALUE
Calendar information defined in CA Clarity PPM is shown in the Set Working Time options in Microsoft Project.
