You can create dependencies between tasks that are not in the same project. An external dependency occurs between two different projects that are not linked by a common master project. The external task is listed in the plan, but unavailable for editing. You cannot edit the external task from the project in which it is referenced. External constraints are fixed. Scheduling does not change the behavior of external tasks.
Note: An internal dependency occurs between projects referenced from a common master project such as when you insert subproject tasks into a project. Tasks are listed in the plan are available for editing just like any another task.
You can insert dependencies into an open project without having to open the project from which the dependent relationship is created:
Note: See the Microsoft online help for more information.
No special rights are required to insert an external dependency into a project or to view linked tasks in your plans.
When a project with external dependencies is open in the scheduler tool, all external tasks are retrieved with their task-level attributes and their external dependencies. No other information is retrieved.
Note: See the Open Workbench User Guide for more information.
When you save a project with external dependencies, external tasks are updated as needed.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
