How Concurrent Timesheets and Transaction Changes are Merged (Scheduler Tools)
You can update timesheets or financial transactions in CA Clarity PPM that may affect information on projects that you are updating. When a project is locked, most timesheets and transaction updates that affect a project are blocked.
The following changes are retained and merged when saving projects to CA Clarity PPM:
Note: Assignments are tracked when the Track Mode field in CA Clarity PPM for associated projects and resources is set to Clarity or Other. Actual, Actuals Thru Date, Pending Actuals and for Pending Estimates data (except for setting it to blank) is maintained from CA Clarity PPM. Any changes you make to these fields from Open Workbench or Microsoft Project are ignored.
More information:
Data Exchanges (Scheduler Tools)
How Project Information is Retrieved and Saved (Scheduler Tools)
