Vary Resource Billing Rates
You can vary a resource's billing rate to more accurately show the total cost a resource has on your project. For example, you may want to show a varying billing rate if a resource gets a pay raise mid-project. You can update a resource's billing rate using:
Example
Suppose that a resource's billing rate is based on the following rate matrices:
To vary a resource's billing rate, in a view that displays resource billing rate data, double-click the resource's Billing Rate cell and enter the new rate. To change altered billing rates back to a single rate for a resource, open the General tab on the Resource Properties dialog box and edit the rate.
Note: See the Project Management User Guide for more information.
More information:
How to Manage Projects from Open Workbench
