Add Resources and Roles to Projects
You can add staff to your project by manually inserting a resource line item and entering the resource details directly in the resource detail pane of a view, such as the Gantt Chart view. To add a resource, right-click anywhere in the resource section and select Insert from the shortcut menu. You can also copy resources from another project you have open in Open Workbench and paste them into your project.
If you are using Open Workbench with CA Clarity PPM, you can add resources or roles to your project from:
Note: You can also add a resource to a project by creating a new resource in Open Workbench and then adding the resource to CA Clarity PPM.
To add resources or roles to a project using Open Workbench
  1. Select File, Properties.
    The Description tab on the Project Properties dialog box opens.
  2. Click the Resources tab.
    The Resources page opens.
  3. Choose to view the Global Resource list by category or by role:
    Note: If you are using Open Workbench with CA Clarity PPM and you have not defined resource categories in CA Clarity PPM, roles is selected and the list box is unavailable.
  4. In the Global Resources grid, do one of the following:
    You can sort the list by clicking the column heading.
  5. Click Add.
    The selected resources or roles are added to the Team Resources grid and are allocated to the project.
  6. Click OK.
    The Project Properties dialog box closes.
More information:
How to Manage Projects from Open Workbench
