Notes Field Mapping (Microsoft Project)
Maps fields from Files Properties or from Task Information, Resource Information, and Assignments in Microsoft Project to fields in CA Clarity PPM.
Microsoft Project
CA Clarity PPM
Notes
None
PRNote: PRCREATEDBY
This field is set to the name of the current user when saving the project to CA Clarity PPM.
None
PRNote: PRCREATEDTIME
This field is set to the current system time when saving the project to CA Clarity PPM.
Comments field for projects
Notes field for tasks, resources, and assignments
PRNote:
PRVALUE
Concatenates multiple notes on the same object (i.e., project, task, resource, or assignment) into a single Notes field when opening the project in Microsoft Project.
How notes are saved back to CA Clarity PPM
The Internal ID is the key used to identify the note when saved to CA Clarity PPM. Do not edit the note or any information. New notes are added after the Add new note(s).
The Intern[date/time note was entered by the user (internal ID)]
note #1
note #2
Add new note(s) under here:
A hard return starts a new note. Blank lines are removed.
