Previous Topic: TNG5935ENext Topic: TNG5937E
TNG5936E
Error on temp file
Reason:
The CA NSM kernel received an “error on temp file” condition.
Action:
CA Automation Point receives this return code from its low-level call to the CA NSM kernel. Ensure that there is enough space on your hard drive, that the CA-AP CA NSM Gateway service is functioning correctly, that the CA NSM Common Object Repository functions outside of CA Automation Point (try creating an object or setting the attribute of an object from the CA NSM WorldView Map), and that the CA Automation Point class definitions have been correctly loaded into the Common Object Repository. If you have taken all the above actions and the problem still persists, contact CA Technical Support.
