The CA ARCserve Backup Job Engine controls the execution time of jobs in the job queue. It scans the job queue regularly, starting jobs as their execution dates and times are reached. CA ARCserve Backup provides the following job engine options:
Note: Single occurrence staging jobs (disk to disk to tape and disk to tape to tape) will be removed from the job queue after the migration phase of the job is complete and the length of time specified for this option has elapsed.
No messages appear.
Only errors that occur while running CA ARCserve Backup appear.
Warnings and errors that occur while running CA ARCserve Backup appear.
Includes all notes, warnings, and errors that occur while running CA ARCserve Backup.
Includes debugging information and all notes, warnings, and errors that occur while running CA ARCserve Backup.
Only administrative shares are available.
Only shares that have been specifically set by users are displayed.
Default value: 256 KB
All computers behave differently. Factors affecting their behavior can be related to backup server hardware, the total size of the backup job, and the number child jobs that a backup job spawns. You can increase or decrease the size of the buffer to optimize your system's performance while performing a backup.
Increasing or decreasing the buffer size does not necessary improve backup and restore performance. For example, if the backup server has abundant system resources, such as a large amount memory, access to a fast network, and fast disk I/O, increasing the buffer size can increase the system's backup and restore performance. Conversely, if the backup server has limited system resources, reducing the buffer size can increase the system's backup and restore performance.
Note: For a typical server, the best practice is to apply the default value of the buffer size.
If you back up hard links files, this information is included and preserved by default.
Default value: ON
Any time a media is to be overwritten, CA ARCserve Backup can prompt you to confirm that you really want to overwrite the media. By default, this option is disabled (OFF). If you set this option, a confirmation dialog is displayed. If you do not respond within five minutes, the job is cancelled.
Default value: OFF
You can turn on the option to back up the Registry key details for target machines by clicking on the Backup registry key details when an entire machine is selected check box.
Default value: OFF
Lets you optimize disk and tape usage in GFS and rotation jobs. For more information, see Media Maximization.
You cannot change this value from a member server. Member servers inherit the value specified for this option from the CA ARCserve Backup primary server.
Default value: ON
| Copyright © 2010 CA. All rights reserved. | Email CA about this topic |
